How do I do the timing chain for RMZ 450?
Posted by: stefi---------------------
How do I do my timing chain for my 2005 RMZ 450? The two top gears have two line up marks, where do they go?
Posted by: HunterMLBMX---------------------
line up your little blue dots on your cams to where you can see one blue dot on the horizontal plane of where the valve cover gasket is and the other 90 degrees clockwise of the other dots position for the exhaust side. 90 degrees counterclockwise for the intake side. + this plus sign represents where your dots shound be. Minus the bottom line of the plus and the middle acts as two dots. There should also be 15 pins on the chain in between the two top inner dots. all of this is of course done at top dead center. If you need a manual i can send you one you can look at on your computer. Ill put it on a usb and mail it to you if you need it.
