| Any suggestions ? I 've changed the pilot jet and needle all over the place. |
Originally Posted by NCFRC
I have a 35mm carb on my 220 and overall it runs pretty decent but I've been chasing a low end , 0 to 1/4 throttle sputter.
Any suggestions ? I 've changed the pilot jet and needle all over the place. I'm thinking it's too rich ,, but honestly hard to tell. |
Originally Posted by jonooffler
Hi this sound just like my bike (2003 KDX 220 stock- I think ), I bought it about 5 weeks ago, at the time I could not ride but the bike started and reved fine all sounded good.
I have just taken it out for the first ride and i feels alful, from cold the engine felt like it was about to die if you opened the throttle it would die It felt like it was running on full choke.As the bike warmed up it got better with the high revs pulling well but low down it is very lumpy and bogged down. The plug is and 8 the gap is fine and its dry but a dark ish brown. I have not tried pulling the carb out to clean it but I'm thinking that maybe the pilot jet may be blocked. The last owner didn't own the bike long and did not know if the last owner a changed the pipe and jets. So any help that you can give would be great. Jono |
.I have decided to change back to a 42 and then flush the tank out a start with a new mix of fuel i mixed the last lot 32-1 so I going for a higher octain and a 40-1 mix to see how that runs.
Thanks for the support mate It's good to know that I have you guys out there.
I going to aviod messing around with the oil mix I want to stay at 40-1 I'm going to check the float level a few people have said about this I just need to know how to check it for my self as so call pro's have said it right but I don't know how they checked it.Jono |
vBulletin Copyright ©2000 - 2010,
vB Easy Archive Final ©2000 - 2010
