Originally Posted by julien_d
6-8psi in the rear, and make sure your forks are lowered down in the clamps as far as they go. I had no problems with the front end after putting the MT43 on. Lowering the rear by adding too much sag is a bad idea. That's going to make your problems worse.
the MT43 does bring the rear of the bike up about 1" over most knobby tires. |
...but the front end on my KDX is sketchy anyway.
Originally Posted by wildman_88
I run a steering damper....Might be a relatively low budget fix.
Originally Posted by Joburble
Yup, dragging up an old thread.
I see that running a trials tire is what some people are doing, very interesting. In regard to geometry can't you just put a lowering kit on the rear to sort it out. I am surprised to see that people are running these tires on their KDX's are they any good in: Deep sand Slick slippery mud Megga slippery wet clay Is there an issue with punctures running them at such low psi? |
The idea with a trials tire isn't to pump it up like a balloon, it's is a low pressure grippy, conforming tire that wraps itself to the imperfections of whatever you are riding over. 4psi maybe 5-6psi at the very most. Don't blame the most untrials like trials tire that was over inflated for the problem.
Originally Posted by sr5bidder
I know not my question to answer, but I run 12psi in front dunlap 756 and 9 psi rear dunlap 803 trials
Originally Posted by mudpack
Yeah, Porter, I was.
I asked because your symptoms are those of a tire that is over-inflated. If you have to guess what the pressure was, then you need to try it again with the proper inflation pressure in it....you may have been over-inflated. I hope this helps. |
| Seems to me it would take *gross* overpressure (17? 20?) to be over the line. |
Originally Posted by porterdog
It raised the rear so far that my front end is skittish and unpredictable.
Generally, raising the rear of the bike will increase front end bite.
Originally Posted by samiam
I have always wanted to try a trials tire, but I am afraid that I will hammer my rim into silly putty with the recommended 4 psi. I imagine that you are running a Bridgestone UHD tube in that sucker...have you incurred any rim damage?
Originally Posted by Patman
I usually don't put a lot of faith in current magazine "tests" as they are usually just an extensive advertisement but this is a pretty good write up with decent information on the subject. Be sure to see all the little roll-over info they have inbeded in the pics.
http://www.dirtrider.com/features/1...ison/index.html |
"If you smack into rocks and nail square-edged bumps hard, you will pay in flat tires and in rim dings."
Eh. I'm out. |
Exactly what I was referring to, using speed to get over things. Some changes in how hard edges are "attacked" results in no damage / flats while getting there in the same amount of time, usually with less crash damage as well
To each his/her own. |
Eh. I'm out. |
