79 KM100 points
Posted by: thebanez---------------------
looking for some information on how to get to/ install a new point on this bike. this would be appreciated.
Posted by: Mad Norris---------------------
The points are behind the flywheel. It's possible to adjust them through the slots in the flywheel, but you really need to remove the flywheel to fit a new set of points.
Schematic:
http://www.cmsnl.com/kawasaki-1979-...list/46118.html
ahh it kind of makes sence to me now. its just i ordered a points set on ebay and the parts did not look like that
Posted by: _JOE_---------------------
Sweet bike! I had one almost 20 years ago.
The points should look like part #10 in this diagram (bottom left):
http://images.cmsnl.com/img/partsli...746118_6d21.gif
ok yes that is what I bought. Thanks all for the help. Do you have to replace the condenser at the same time?
If the condenser was working, there's no need to replace it.
You'll probably need a flywheel puller to get the flywheel off, which is the hardest part of changing points.
Hmm I see. The set I bought came with a new condenser and wasn't sure if it was a good idea to replace it at the same time. I have to admit I have no clue about electronics like this on bikes. So my main concern is doing any further damage.
If you have a new one it would be silly not to change it out while the flywheel is off. Keep the old one as an emergency spare if it's still working.
Yeah, as _JOE_ said.
With the battery disconnected, you can't really damage anything by messing around with the points & condenser (unless you use a hammer). If you do happen to connect the wires incorrectly, or set the wrong points gap, the bike just won't start (no spark), but no damage will be done.
