overheating
Posted by: unclefabby5---------------------
whats the best way to stop overheating in the tight stuff? my bike is a 08 450xc. hair&hounds are the worst!
KTM fan kit is pretty easy bolt on and pretty cheap .
Posted by: sloopy---------------------
That is weird that your bike is over heating i have never had any problems with over heating. i ride mostly tight stuff. maybe you should look into engine ice or there is some other stuff that is more of a goo, not sure what its called.
i did have problems with over heating my clutch went to a DP clutch with thicker plates, disapates heat better. Make sure you dont have any air pockets, bleed the coolant system.
oh yeah, i forgot. until i rejetted my bike from the stock super lean settings it ran pretty hot, my exhaust turned purple.
