Originally Posted by _JOE_
If it does it at half throttle it should be needle or main jet related. Did you have the carb apart during the rebuild? I would start by verifying that everything is spotless in the carb and the float height is correct.
Originally Posted by rmrider45
i had the reeds checked today and they are fine. i went out and bought a couple of jets a 128 122 and 120. tried the 122 and it got a little better. put in the 120 and it runs fine. seems to have changed the power band acording to my son. bike runs good and it is snappy.strange why the smaller jet the 120 worked when it calls for a 125 stock.maybe me running synthetic klotz oil changed something not sure.
Originally Posted by whenfoxforks-ruled
You did not read the jetting information? This winter you will be putting the 125 back in. How many turns out is your air screw?
A tired engine would require a starting problem you have described. But, a bad float valve will flood the engine with fuel and require the same starting technique.
The main jet has no effect on starting. Look to the pilot jet, that is once you verify the float does in fact float(at the correct height) and the valve is new. How old is the lower end?
A top end not sealing up good will not pull a fuel mixture into the carb properly. I have read that its a fresh top end, but? I reread through the 3 and 4 turns out on the air screw, then you told me 2? Can you achieve a high idle at all, adjusting it in and out to find the spot? Can you bite the bullet and pull the top end and measure the ring gap, skirt clearance, check for abnormal wear, cylinder out of round? You will need a bore gauge to check the last part.
strange thing is when you give the bike gas it seems it cant burn the fuel fast enough.
If the bike is loading up, and clears out past half throttle, right crank seal or the carb is flooding the hell out of the engine. A leak down test would resolve the seal question, replacing the float valve the other. BUT, a top end not sealing up properly can do the same thing. A leak down test can show the top end not sealing properly also. A compression test is only a good reference if you test it when its broke in, and keep checking it to see a noticeable drop, top end worn out. It can be real deceiving if not used properly. You should be able to smell the difference between the engine burning klotz and whatever trans fluid you are using?
