For Sale: 2005 CR250r Very Clean!!
Posted by: flattie---------------------
Meticulously expert maintained 2005 CR250r.
After every race:
Washed, filter cleaned, chain scrubed, air box/sub-frame removed and washed, transmission oil changed, levers removed/cleaned/lubed, throttle tube cleaned, spokes checked/tightened, chain checked or ajusted, checked reeds, wipe plastic and rims with maxima SC1.
Every year/spring:
New Wiseco piston kit, New Barnett clutch kit, New reeds, New Renthal chain and sprockets, New Twin air filter, New Renthal brake pads, New Moose muffler packing, clean power valve, grease linkage/swingarm/steering stem
List of goodys:
Eric Gorr (Forward Motion) port and head work
V-Force 3 reed block
Pro Circuit platinum pipe and 304 silencer
PC pegs
PC axle blocks
PC graphics and seat cover
Michelin MH3 tires (front 90% rear has 3 races on it)
Barnett clutch kit (heavy springs, steel plates)
Renthal chain and sprockets (50 tooth rear)
Renthal Brake pads
Renthal Windam/Carmichael/OEM 7/8 bars
Renthal full diamond grips
Applied 7/8 rubber mounted bar clamps
Maxima Coolanol coolant
Maxima MTL transmission fluid (changed every ride/race)
Maxima Super M mixed 40:1 with TT111 or VP c-12 (jetted accordingly)
Moose wheels
Moose steel shifter
Buchanon stainless heavy duty spokes
Hubs bead blasted and holes chamfered
Pivot Works wheel bearings/seals
Works Connection guide plate
I will guarantee absolutely no problems at all with this bike. It is race ready! Raced nearly every weekend, i've had the bike since new and has been maintained this way for the last four years.
$2500 firm
Any questions or need pictures just call me or type me with an address.
Located in Hartman, AR. 40 miles/minutes east of Fort Smith
Brian 479 518 0157
no takers?
need a 2010....
