05 TTR 90 - Lost Key. How to bypass ign.
Posted by: CaptCon1---------------------
We lost our only key for the TTR 90. Have a trip planned for Ocotillo this weekend with all the kids.
Is it hard to bypass the ignitiion switch or am I going to have to take the walk of shame to the dealer?
Any help would be appreciated.
Thanks,
Posted by: Patman---------------------
Should just need to jump the wires.
I have 4 wires to deal with. 1) Red 2) Brown 3) Black 4) Black with White stripe.
Which do I jump?
Posted by: Matt90GT---------------------
Get a few extra fuses. I believe you need to jump the red to the brown.
Posted by: helio lucas---------------------
just unplug the black\white wire and your'e done. you may do that at the CDI.
Thanks. I will get some fuses and see what happens tonight.
I believe lucas is correct. By unpluging those wires you bypass the key switch's ability to ground out the ignition like the kill switch thus letting the bike start.
Posted by: fisher54---------------------
If its like the honda just unplug it.
Red wire switched on a 2 pole rocker with Brown wire. New 10amp fuse because of attempting to "jump" all 4 wires together. Both Black wires were taped off. Works well.
Thanks for all your help.
All is good.
I almost forgot, the Red wire and the Brown wire complete the circuit to allow the electric starter switch to excite. Once those 2 wires are "switched" or "jumped" it is as if the key was in the "on" position. The 2 black wires when connected are a kill switch. SO, when the stock key ignition switch is turned to the off position, the engine shuts off. Since I eliminated the key ignition switch and used only a rocker switch, the kill switch feature was not needed as the bike already has a handlebar mount kill switch. Because I didn't need the wires, I just taped them up.
