timing for kx 250f
Posted by: aples28---------------------
hi guys having probs with my 04 kx 250f .........was just wondering if anyone knows the timing for this bike as timing may be out?backfires after maybe 10 -15 kicks,new rings and valves (have been seated) a little compression but needs plenty more...... checked for cracks etc... cant figure out why wont start???????? any info will be greatly appreciated
thanks guys
Ignition timing or cam timing?
Your ignition timing is set and can't be changed.
Most likely your cam timing is a tooth off. Refer to your service manual for the correct way to set your cam timing. If you don't have a service manual, you should get one.
Also, if the bike has been sitting for a while, your carb may be gummed up. Especially if it had race gas in it. Clean the carb.
Posted by: Matt90GT---------------------
PRetty easy to time the cams. Find the TDC mark on the flywheel, then the hash marks on both cams will be level with the top of the head. Exhaust lobes will point forward on the bike like 10 oclock position and intake will point back at like 2:30 position
Get a manual if you need more help
