help with a ts 125
Posted by: gordee---------------------
i have bought a 74-75 suzuki ts 125.it was in a barn for years. my question is this i have the motor and the coil is this the only electrical parts i need?i am not running any lights or anything.i know i need a kill switch but do i need a RECTIFIER ,cdi box?it does have a kick starter. thanks
Posted by: bchunter---------------------
I have a 79 TS 250 and if they are the same you will need the coil and cdi for the ignition and that is it. The magneto powers the headlight, the spark, and the charging of the battery. You do not need the battery to run the bike, only to light up the turn signals and accessory lights, which as you say you are not using. The rectifier is only for the battery, so if you are not putting a battery into it, then you are good to go.
Posted by: AjayMike---------------------
I had a '72 TS125. It had magneto ignition, and did not require a battery for it to run.
When I brought it home from the dealer, I stripped off the lights, turnsignals and battery before I rode it the first time.
Mike
That is how I got mine, stripped of all lights. But I like to ride it on the hwy as well, so I have put lights back on it.
i was told that i should only new a coil since it is a points ing. is this true?got a new coil but still no spark.can anyone tell me what wire should go to the coil? i have a yellowwith red stripe,a yellow with white stripe,a green with white stripe,a black with yellow stripe,and a black.i am not sure if this is the right motor for the bike . thanks
Wow, sounds like you got some work cut out for you. Lets start at the begining.
First off, the engine will have a serial number. The first couple of letters and numbers will tell you what make the engine belongs to. On mine it is TS2504 - xxxxx, hence a TS250. It is also my belief that the last digit will indicate the year, so mine is a 1979.
Second, I am basing my info that the 125 is similar to the 250. You should research the 125 to be sure. The 250 does not have any points, the ignition energy is produced by a PEI (point-less electronic ignition), to which the energy for ignition is produced by the magneto.
With that being said, the coil is located between the PEI and the sparkplug. It has (again on mine, I am not sure if yours will be the same) a white with blue tracer and a black with white tracer going from teh PEI to the coil.
As for all the wires you listed above, are those the wires that are coming off the magneto cause that is what it sounds like. There are simularities between mine and the ones you have listed, but only you can tell. Another good start would be to get a wiring diagram for that bike that way you can be sure you are hooking it up correct. If you have a Suzuki dealer close by, they sometimes have the old service manuals for these bikes. That is where I got mine.
Good luck.
i got a manual but the wire colors dont match.and the numbers are all messed up on the motor(which kinda scares me)
Ya, that does sound scary.
Are all those wires you listed above coming from the coil?
they come from the motor all the wires are in a black plastic tube th comes fromthe side where the magnito(i guess)is located
OK, that makes sense. The colours might not match if the wiring diagram that you have is for a bike made in a different country. For my bike, the wiring diagram for bikes made for the Canadian and US markets is the same for those in other markets.
How far off are the wires that are on the motor to the diagram? The colours you listed above are the same on mine except for one, but my diagram has 6 wires from the magneto while you only listed 5 above.
Let me know what you think, I can take the time to list the routes of my wires if you think it will help.
