CR forks in a Kx
Posted by: Shagy100---------------------
I was wondering if anyone could tell me if the shawa forks from a 2002-07 cr 250 would fit an 03 kx 250. I wanna get rid of the old style suspension that Kawasaki had from 94-03 and go with something a lot nicer.
Posted by: Matt90GT---------------------
ANything can be made to work. You might be better off getting the 05+ KYB twinchamber forks off a 05+ KX250. You will need the clamps, stem and possibly front brake caliper and wheel. Check the parts fische to see if those parts like the brake and front wheel are the same for your year.
Now if you want the showas, get them off a 06+ KX250F. Your brake and front wheel might work on those, but again check the parts fische.
You are going to have to get new clamps with any of the newer twinchamber forks. Staying with a Kawi set will make it easier than swapping from a Honda or Suzuki
i am lookin to get showas. i thought that the 06+ kxf used kyb forks
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
