Float bowl keeps sticking!!!
Posted by: Garster---------------------
So my float bowl in my carb keeps sticking. When its stuck and i trun on my gas it comes right out the bottom of my carb. I can make it unstuck by hitting the side of the carb with a hammer lightly. But when i runs and i turn it off, or even while its running it will start to leak again. Any solutions?
Posted by: Patman---------------------
Uh.... clean it? Then adjust per factory specs? Usually works for me and everybody I know. If you are 1000000000% you have it perfectly clean and adjusted then buy a rebuild kit for the carb it will have a new float valve.
Even I don't pay attention to every little detail and get burned. Just today I was cleaning the carb on our hot rod XR80 because it wasn't running right. I pulled it and disassembled it cleaned everything really well, reassembled it, set the float and popped it back on. Still not right. I pulled it off and double checked everything and found I had a blocked passage when I tried blowing in the vent tube. A little more cleaner and some compressed air solved everything.
BTW the bowl is the bottom "bowl" of the carb that holds the gas. Get it? Bowl.
Posted by: cruton1989---------------------
my carb keeps pouring gas ive talked to different people and i have been told that it may be a stuck float or the o ring on the needle is wore out how hard is it to fix
o yea im pretty new to dirt bikes so all i know is how to put gas in and ride the crap out of it
