Rear tire kicking up and swaying side to side
Posted by: mandown310---------------------
Can anyone offer some advise on how to fix the following. When I ride through a bumpy section or through some whoops, the back end of the bike kicks up and sways from side to side. I currently have the high/low compression and rebound settings to stock.
Posted by: RM_guy---------------------
Slow down the rebound on the shock. It is extending too fast. If you slow it down too much it will pack--never extend all the way when riding through rough sections--so play with it. It's always good to go to the extremes and then back it off so you know how it will react. Just adjust one setting at a time so you know what did what.
Posted by: whenfoxforks-ruled---------------------
Are you sure you still have dampening? Is it REAL springy just sitting? If you are riding indoors, bury the clickers, it stiffens and slows everything down. Thats a local pros advice on fixing swapping. Vintage Bob
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
