Clutch on 2006 YZ450f how much noise?
Posted by: drrm123---------------------
How much noise should be coming from a 2006 yz450? With bike in neutral and clutch lever out it rattles and is noisy with lever pulled in, it quiets down. When I rev the bike in gear with clutch pulled in it tries to creep a little is this normal? Pulled clutch apart last night and plates are with in specs and throw out bearing is fine. Also no grooves worm on basket.
Posted by: sharky243---------------------
They have a normal rattle to them. Mine sounded like that from new. The steel plates are probably warped, that will cause it to drag. That makes it try to creap and be hard to find neutral when the engine is running.
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
