wrf shock linkage bearings..A TOTAL JOKE!!
Posted by: cw242---------------------
i finally got around to tearing the new wrf 250 apart to grease all the bearings, i did expect to find little or no grease in them but to my horror i find the most abused bearings on a bike, the shock/swingarm linkage bearings had some kind of plastic/glue in them instead of grease??? no it is not hard grease!! diesel fuel dissolved it to some extent , enough to get the rollers apart and set them in some mobil 1 good old red grease.. be warned these bearings are not encased in a cage they are loose,if you lose one roller you are screwed, what a joke, how long could these possibly have lasted, there was no grease nor could you have ever put any type of lubrication on them,, no not even K-Y!!! pitiful!!:think
Posted by: ACS---------------------
Ive noticed the same. I think it is some type of plastic lube rather than a grease. It holds the rollers in place for assembly I think. It dissolves in solvent. Its been in Yamaha YZ's for a few years now.
Posted by: J_dem_Bones---------------------
ya..I was a little upset myself when I pulled mine apart.
My head set (where the triple clamps mount to the frame) was the same way. I took it all apart and re-greased it all. :think
So make sure you check these area's when you buy one!
Thats the only negitive about my bike.:D
Posted by: Hick---------------------
Same on the bigger YZs, I leave the plastic stuff in there. Seems to work like a cage of sorts, holding the bearings in place. But I think it is fine to remove it as well, maybe better since it will hold more grease.
There wasn’t much grease at all on my ’00 or my ’01 as delivered, maybe with the yellow plastic things they don’t need as much. Whatever...
i guess its all in what your comfortable with,, for me a little grease seems to go a long way as long as you have good seals, maybe im old fashioned but the yellow glue junk just doesnt seem to help me sleep better at night!!
:confused:
Posted by: MikeOK---------------------
This comes up all the time on the YZF and WRF forums at www.thumpertalk.com
It is in there to aid the little japs in assembly I am told.
