Originally Posted by julien_d
I'll go out on a limb and say the larger carb size makes a considerable difference in top end performance. So for that, one carb is certainly "better" than the other. Likewise, the smaller carb provides better throttle response at lower rpm's, just like Reep has said. So if what you are after is low end throttle response, the smaller carb would be "better". Yes?
Originally Posted by mudpack
If I were the OP, I might port the 220 cylinder to 200 specs, put the 200's carb on it, and have a nice ride.
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
