2000 426 fork oil height
Posted by: MXTex---------------------
Any recommendations on fork oil height for a 2000 426 would be greatly appreciated. Bike is used for MX only.
Also looking for fork oil height recommedation on a 99 YZ250 used for MX.
As you can see, I'm servicing several friends forks.
Thanks in advance.
Posted by: SoCal Steve---------------------
Tex;
The Yamaha spec is 135mm for oil height on your 426 as well as the '99 250. You can raise height to add bottoming resistance. My revalve setups for customers riding MX are between 90-100mm. I have heard of other tuners spec'ing as high as 65mm. You will have to experiment to find out what works best for each rider. Ask if they are bottoming hard and raise accordingly.
Steve
Steve,
Thanks a million for the information. I'll set tham at 100 mm and dial from there. Again, I really appreciate your taking the time to post this information.
Jim
Posted by: Anssi---------------------
For my 2000 YZ250 forks (probably very nearly the same as the 426's), I tried 100 mm, and got lock about 10-15 cm from bottom. About 125 seems to work for me, and I'm a big guy (220 lbs.). Oil is 7,5 wt.
