choke not engaging!
Posted by: 2stroker144---------------------
so i went to go start my yz250f (2005) and the choke wouldnt engage. i could pull it out, but it would just go right back in. it wouldnt stay out... anyideas? is it just a spring or something...im hoping its an easy fix. thanks to any who reply
Posted by: whenfoxforks-ruled---------------------
Unscrew the lock nut, and inspect. Poor fuels or debris can foul it up, and if any debris is present, it went into your motor as well.
Posted by: pesky nz---------------------
I have had this happen and inside the small rubber booton the choke shaft there are 4 plastic ratchet teeth and these had worn or lost there tension or both. I managed to fix it with some tie wire to put tension back into the lockers. It lasted a couple of years but eventually a new (and quite expensive at the time ) choke unit had to be fitted
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
