1988 Honda XR200 transmission locks up
Posted by: HondaBrat---------------------
I have my brothers 88 XR200 on the bench and case split. This thing locked up on me in 2nd gear. I have checked everything in the transmission and found nothing but some worn bushings on the main and countershaft. Do you think thats enough to lock it in gear while doing a wheelie.
Thanks,
Mike
Posted by: mideastrider---------------------
Are you saying,"Engine still runs fine but the transmission is locked up in 2nd?"
No it wont run at all. It has unlocked once or twice. Acts like a piece of metal is getting stuck between the gears.
What I am trying to understand if its the engine or the transmission. Its not uncommon for those old xr's to starve the top end of oil when riding (excessive/long) wheelies. When that happens it can lock up and when it cools down it will free up again. It the transmission was locking up I believe you would see it if you have the tranny apart. Pop the cam out of the head and see what it looks like. Maybe some galling on the bearing journals.
Top end is fine. Dosen't have even 3 hrs on it. Guess I'd better buy all new bushings for both counter and main shafts since I dont see any broken gears. I have the same bike as him and I lost 3rd gear years ago.
Quote:
That sounds right.
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
