Number plate installation
Posted by: KDXer---------------------
Have any one installed a KX number plate, but kept the standard odo meter on. Any tricks to get things closer to the clamps ?
Posted by: FLBob---------------------
I took the front plate/light off my 220 for HS, and will put back on if I ride any enduros. So, I'm in the middle of mounting a generic number plate right now. I decided that behind the plate was a good place for a tool pouch, so I'm making a braket that will hold the plate away from the ODO. Works great in my mind! Where do you carry your tools? What do you carry?
Posted by: jackalay---------------------
If you are ditching the headlight do you really need the odometer?
Quite right. I've decided to remove the odo as well. I might considder a electronic unit later on, or not...
Posted by: trips67---------------------
Has anyone installed a numberplate with a WER damper? If so which number plate works best?
