XR400 Burning Oil
Posted by: tuckmt---------------------
My '96 XR400 is burning oil (approximately 8 oz after 20 hours of riding).
I imagine that this is not normal.
A couple of observations:
The spark plug has an burnt oily residue.
Just changed the oil and went to Honda 20W50 (mostly riding in hot south).
I have the Honda Service manual but it really just tells how to tear it appart and put it back together.
Some troubleshooting would help me here: valves? rings? etc.
What should I do next?
Thanks in Advance
Posted by: BigBore---------------------
First off, try a compression test. Most likely, you've just got a worn out top end. Yes, it is possible that oil can get into the combustion chamber by getting past the valve stems, but I would start by checking the condition of your piston rings.
Any idea what compression I should expect on XR400?
