:think
in the whoops. Wanna know the damping curve I want? I'll design an inertial valve that reduces damping to near zero under high acceleration. What this would do is let the wheel move freely when it gets a sudden jolt and then smoothly apply damping as the acceleration spike subsides - arresting further wheel motion but avoiding the spike. All this needs to be is a spring and a mass driving a spool valve or perhaps a needle. Put that in your pipe and take a good drag......
Guess when I get the new bike I will revalve. The only problem I can think of with this set up is a "dead" feelig in the top part of the stroke and packing problems as the spring will not have much stoored energy.
Originally posted by KXVET#207 Mace, lets kick that inertial valve idea of yours around some more...... ![]() |
Originally posted by KXVET#207 variable displacement piston rod. With the narrowest part of the taper in the center of the rod. [/B] |
Originally posted by michigan Sheeshz. I only ride in the woods, so in most places I'd be happy with heavy springs and light valving, but Michigan woods are filled with big ole' whoops. |
Originally Posted by tmoney
John, this reading is great. Thanks to yourself and Jer for facilitating "out of the box" thinking. I myself am no suspension guru but enjoy thinking about how to get what I want..jer is helping me now sort out my issues and thankfully so, as I was about to try a stack that was prone to fail....
Anyhow...would a dual stage mid valve piston work? First piston would mimic what is typical today...ports leading into a valve stack arrangment that has designed strength and deflection to suit the initial desired action (ie. plush on low to mid speed hits with dampening only moderated by the first piston/valve stack...second piston would be smaller in diameter to allow fluid to travel past the entire piston body under low to mid speed hits. As the assembly moves through the fluid under high speed/high acceleration the fluid would not be able to bypass the second piston entirely, thereby finding the path of least resistance via ports and a second valve stack which could be designed to dampen only the high speed/high accelerations. This could allow a fork to be plush but still take the g-outs with sufficient bottoming resistance. Could agrue this is the same as 2 stage but there has to be some advantages to having a piston/stack arrangement for low and high speeds????? |
Originally Posted by fishhead
I say the same for enduros although this option was not on the list. In our part of the country the enduros are usually on much rougher terrain than a HS.
Originally Posted by Yoken
When I race a MX track, I tune my suspensions mainly for the turns. In Cyprus, most of our tracks are made of hard clay and rocks with supercross type jumps and tight turns. I definitely go for the following setting:
- relatively hard springs, but with low pre-load, - moderate low speed compression damping, - light high speed compression damping. It seems that the low pre-load (3 to 5mm on the fork springs) keeps the fork plush and more responsive on small bumps. Also, it allows the front end to dive moderately when I set up for a corner (I need that because my KX does not turn if the front end rides too high). Than the springs get harder as the fork goes deeper into the stroke. This usually gives me sufficient bottoming resistance. I need moderate low speed compression to keep both wheels on the ground in the turns. The light high speed damping helps me to reduce "vibrations" in the bar as I ride a high speed section with little bumps and rocks. For those slippery conditions, I like to run a low air pressure in the tires (around 800gr only). And I install 2 inner tubes to increase the resistance to puncture. |
, and the Sherco was great in even the ugliest terrain. But I think the soft suspension made the bike feel heavier than it actually was?!|
