Sag ...is it really important?
Posted by: MONjean---------------------
Before Unscrew completely the subframe of my bike and buy a special tool for adjust the sag at 90mm for the Mx track...
...is it really important to up a 60mm sag to 90mm?
i have a 250kx 01 and my weight is 169lbs.(the SAG is stock)
what do you think?
:think :think :think
Posted by: Smitty---------------------
Yes, 30mm is a huge change in sag! Sag is measured with your weight on the bike versus on the stand. You don’t need to remove the subframe to do this. Usually you can loosen the top jam nut with a punch then turn the spring with your hands which should turn the bottom preload nut.
The bike will be very twitchy and unstable with only 60mm of sag, so I wouldn’t even think of skipping this adjustment
yes my bike is unstabe and he slide in the turns...
i had try with the punch but the top jam nut is really tight...i will try with the
plumber key for loosen this nut..
thanks for the info Smitty, i am hasten to try my bike...
(and i skipping this adjustement because the stock setting of this bike is supposed fitting with 170 lbs man...???)
Posted by: Jaybird---------------------
MONjean,
Motocyclettes sont installent approximativement pour 170lb. cavaliers. Celui-ci n'a pas l'intention ce qui il va être correct exactement parce que vous. Allez pourtant la procédure complète pour monture s'affaisse et vous aimerez le chemin votre vélo manie.
(y'all thought I was just an ole hick, dint ya!)
Posted by: azcourt---------------------
Quote:
Originally posted by Jaybird
MONjean,
An old hick with a bad accent You must be from New Orleans
LOL...you mean Nawlins!
Non, je seulement a une traduction mauvaise programme.
