YZ timing for the woods?
Posted by: wayneo426---------------------
Id like some opinions on YZ timing for my WR. I have thought about this, but am hesitating because most of my riding is done in the woods. I love the quick revving that I will get for the track, but am not sure it will be as useful in the woods. Thanks for any opinions.
W-O
Posted by: MWEISSEN---------------------
Wayne, I'd suggest doing the gray-wire cut first if you haven't already. I noticed more difference doing this on my bike than on another WR I rode that had YZ timing and no clipped gray wire.
Posted by: Humai---------------------
Wayne, my WR (a euro spec model), when I YZ timed it, developed much more torque in the low-mid to upper-mid range. Low end was a little softer and top end was about the same but the mid range was much better than with the WR timing.
I much prefer YZ timing in the tight woods, as I can run a gear higher in many woods terrain situations with the YZ timing. My guess is that you will greatly appreciate the YZ timing mod (once the grey wire mod is done as MWEISSEN points out) in most of your woods riding.
BTW I had to richen the main up a couple of steps (170 to 175) for the YZ timing.
Posted by: BikeDstroyer---------------------
I have to agree with Humai. I have the 250WR & not the 426 but the concept should be the same. I went to Colorado the first time with the grey wire mod but WR timing and the bike worked fine. The next time I went I changed to YZ timing and it was actually much easier to ride. Throttle response was much better, easier to get over logs & such. I didn't have to change my jetting but with the 426 I guess you might have to. Change it and have a blast. If you for some reason don't like it you can always change it back.
Posted by: Scott in KC---------------------
I for one, am all for it! That way you can tell ME if you like it or not before I do it.
Thats funny Scott.
"Better you than me" is one of my favorite sayings!
I have done the grey wire, 23mm throttle stop, trashed the airbox lid, and put in a UNI filter. I have ordered a YZ needle EBLN, and am re-jetting the bike next week. I went with a #168Main, 100PilotAir, 48Pilot, per James Dean. This bike should RIP thru the woods when done. Of course I will need to max out that power by going to YZ timing, as well. Wheel spin is great, but Id rather hook up with the earth, not just throw it.
I would love to ride a YZ timed bike, but the change seems simple enough to do, even for a guy like me. The other alternative for punchy power in the bark is going to the 52 rear. I have heard great things about this on the ThumperTalk boards. Guys swear by this. Any comments?
Wayne,
Do you have the 168M/100A/48P jetting now, or are you going to wait until you get the YZ needle? If it's in now, I'd appreciate a note on what happens when you put in the YZ needle.
Sounds like someone had better results on YZ timing than I did. I didn't change my bike, but rode a partner's bike that did, and I thought mine was stronger. I don't know how the YZ'd bike was jetted, and we know that these bikes don't like to be too lean!
Mark-
I plan on doing the jetting with the new needle at the same time. I trust JD, and the results he has gotten for so many people. I also think the difference will be a substantial one. :D
Even after YZ timing, the jetting should be spot on. Jetting is soooo crucial in these beasts!
