MX2T and Powervalves
Posted by: mike_h---------------------
Rich, I read almost every post on MX2T in the archives, but never heard how it is with keeping powervalves clean or not. Have you done any top-end jobs after running this, and if so, do you feel that this is an oil that will limit the amount of buildup on these parts?
Posted by: IBWFO---------------------
We have been running Motul 100% synthetic (60:1) with VP MR/2 for a little over a year and have had some awesome results. No failures and the best (least) carbon buil-up on the piston/powervalve ever. We used to use Silkolene with some good results too, but nothing has surpassed Motul.
Regards
01 Cr 125
02 CR 250
Posted by: motometal---------------------
60:1...playin wit fire:o
Posted by: Strick---------------------
Mike, I have ran MX2T in my 300 at 40:1 and 32:1 mixed with 50/50 race/pump gas, exclusively on this top end. I will be able to answer your question in around 200 more miles. I will be replacing the entire top end at that time. I too am real curious how the powervalve is going to look. My last top end the powervalve using only Golden Spectro, was a mess!
Quote:
I ran my RM150 on it all last season with the mix varying between 14:1 and 20:1 with the majority at 18:1. I pulled the top end apart at the 30 hour mark and the power valve was clean enough to not require service. Eric had the bike when I got my CR and took the top end apart some time later at approx 50 hours and saw nothing in the way of deposits either. Half of the hours on my CR125 have been run on MX2T with similar results. It's not a very scientific test or sample but I was very pleased with the results I got with MX2T and would feel comfortable recommending it based on what I've seen up to this point.
Motul @ 60:1 with 100% race gas isn't a problem, especially if you know how to jet and are meticulous about it.
I wasn't suggesting it would be a problem, but parts tend to wear out faster with less lubrication. If you do a search, you will find some pretty convincing arguments FOR running more oil and AGAINST running less oil (such as 60:1). Anyway, this topic has been beat to death, so I'll stop there.
