| . I tried jetting the bike richer to get rid of the bog, but then the engine would get loaded up in the slow sections. |
| ..lots of potential there... |
| ..more air..larger opening |
| It's a matter of pressure differential..NOT 'more air'. A difference in pressure is what causes gasoline to be PUSHED from the fuel bowl into the carb. Removing the airbox cover DECREASES the pressure difference (it's easier to 'suck' air through a larger opening), which ends up with LESS gas being 'pushed' into the carb venturi. That's why you jet RICHER when you decrease the pressure differential..not because there is MORE air. |
| It is easier to 'suck' more air through a larger opening |
Originally posted by Lutz No, that's not right. Taking the airbox off actually increases the pressure differential. Remember, the float bowl is vented to the outside atmosphere. This means MORE AIR into the carburetor. More air into the carb means higher velocity through the venturi, meaning lower pressure in the venturi. |
At wide open throttle, the fuel circuits are primarily exposed to the air stream moving into the cylinder and the low pressure it creates, and depend very little on the low pressure created by the piston. That is, at wide open throttle, the low pressure on the outlet side of the carb is balanced by the high pressure on the air at the inlet side of the carb, and the fuel circuits have very little to do with balancing the pressure. However, fuel is still pushed into the carb at wide open throttle because the air is moving through the carb (and over the fuel outlets) at high velocity, and therefore at low pressure.| If your air filter gets clogged your air flow decreases and the pressure in the carb drops because not enough air can flow through the filter to equalize the pressure in the carb causing the gas (which is at atmospheric pressure) to try to equalize the low pressure area richening the mixture. |
