bend on crf450 bars?
Posted by: dheard4992---------------------
i want to put pro tapers on my crf450 but i love the stock bend. the bike just feels right to me.could you please tell me what to order as bends with riders names on them dont tell me much. thanx ,dave
Posted by: ochster---------------------
Bar choices are obviously very subjective, but I did just set up a CRF450R for a lifelong CR rider who is 6' 0". We ended up using the applied mounts with the offest facing forward, giving us about 4mm's more room. We used the CR-HI bend Pro-taper #02-4746 (silver). This bar appeared to be about 10mm taller than stack with a couple mm's more pullback. This combination felt really "normal".
Posted by: IBWFO---------------------
The stock bars are CR Low, and you can pick up some Pro-Taper mounts and you don't have tp change the top triple clamps. Honda triple clamps are some of the best stock triple clamps around. I would listen to the previous guy if your tall. I'm 5-8 190 and liked stock positioning.
I went with silver CR Low Pro-Tapers and just changed the mounts.
Also, if ya stay with the "stock" triple clamp they will be rubbr mounted. (another plus)
Good Luck
im 5-8 195 and the bike felt right so i think ill do what you did.thanx for help
