xr 250
Posted by: tstorms---------------------
I have a 1993 xr 250 that's used as "friend" or second bike. I've noticed lately that there is very little resistance with the kick starter. I can still get it started yet not as easily and it doesn't "fire up". Otherwise the bike runs perfect. Should I worry?Any ideas to the culprit?
Posted by: 84XRGuy---------------------
Start by checking the valve clearence.
Posted by: TobyS---------------------
Also, check the decompression cable adjustment, or take all the tension out of it, just to check.
Posted by: roostafish---------------------
Or, heaven forbid, if it has lots of miles on it, the rings may be worn. Do a compression check if your valve adjustments fail to satisfy.
