Fav. Pro-Taper bar bend?
Posted by: gibbs_6---------------------
What Pro-Taper bar bend do yall like most on the overized bars or if you have any suggestions on what would be the best I am 5'11 so if that matters and I hope I still grow some more being only 14.:think
Posted by: Strick---------------------
I am 6'00". I like Doug Henry bend, and CR mid.
Posted by: Asrith---------------------
i was goign to post a message about these bars, my question is that will these fit on all bars? I am 5'10" and liek the bars up higher since I am always standing. I own a KDX 220R. Thanks!
Posted by: ToddHawaii---------------------
I would recommend the Pro-Traper High Woods Bend. The bars are higher,with less sweep(pull-back).
Aloooha!
TrailTramp
Posted by: Jason81---------------------
For me there is nothing but the high Honda bend.
I have used others and this is my favorite. When changing bikes I always use the same bend and this helps to make the transition very easy.
Ok for the riders near or around 6'.What do yall use?:think :confused:
Posted by: justql---------------------
I'm right at 6'. I think the ones I use are CR high bend. It also depends on your bike.
2000 yz 125.....:think
Posted by: CR Swade---------------------
I've started using the Magura KTM SX bar. It is roomy, aggressive (not a lot of sweep back-even straighter than the ProTaper) and priced excellent-amundo:confused:
Posted by: redrider4---------------------
I'm 6'1" and use the CR mid on my 250.
Posted by: selmgren---------------------
I ride a KX500 and use the Doug Henry bend, Pro Taper bars. They are pretty straight (not much pull-back), great when your up on the pegs. I,ve talked to Destry Abbott about bar selection and he uses Pro Taper CR-high bend. Forgot to add that I,m 6'0".
I think I'm leaning toward the Doug Henry bend right now or the CR High bend.Anymore suggestions?:think
Ok I figured it out.I'm going with the Doug Henry bend since it has a little less height than the CR High and more than the CR Mid.Also it has less pull-back than both of them.Thanks for all the replys.
