ALPINE STARS VECTOR Boots
Posted by: EricGorr---------------------
When I was an editor for Dirt Rider magazine answering questions for the Ask Dr. Dirt column, one of the most popular questions was “where can I find a boot to fit my calves”. Being a lanky Swede with skinny legs I couldn’t relate. I wondered how big are these peoples’ calves anyways, and why there were so many. So I turned the tables and asked them questions, asking for physical dimensions of their calves so I could compile the data and forward it to the boot manufacturers. I also asked these guys what they were doing right now to protect their feet or modifications to their conventional boots. Well as you can expect there were a myriad of ideas ranging from duct tape to zip ties, to hoes clamps and re-mounted top buckles, and even one guy who just cut the boots off, half way up his massive calve.
While I was collecting info on boots people offered other comments like is there a boot that has a smooth tip, or a curvature, and a replacement sole or high wear spot. When I pulled the VECTOR boots out of the box I started to chuckle with glee. Some smart Italian guy finally started listening to Americans and built an interesting new boot design.
I couldn’t find anything that I disliked about the VECTOR boot, so lets look at the good stuff! My last set of Apline Stars took a full year to break in because of the stiffness. The VECTOR is comprised of several sections stitched together to enable movement without having to be broken in, which is good because motocross is painful enough without having to suffer through the break-in period.
The next obvious feature that struck me when I strapped on the boots was the natural shape. “Lazy Feet” is a condition that causes knee injuries to riders. I’m cognizant of my lazy feet behavior so I tend not to take them off the pegs, I’d rather augur myself into the ground and take my chances rather than injure my knee by having my forward or rearward dragging foot hook something in the ground. The VECTOR skims over the ground with its curved up smooth toe, so I don’t have to consciously bend my foot up. It’s a bit of a slippery feeling too but if you do need to stab your foot into the ground to keep from falling, it’s still very positive.
The smooth toe works in the opposite direction too, like when you pivot in a turn and rotate your leg behind you and drag your toe, like in slippery conditions. My older model Alpine Stars had a distinct junction between the sole and the boot that served to hook objects in the ground.
Of course the whole “Big Calve” issue has been addressed with an adjustable top strap that the Incredible Hulk would appreciate. But it is a bit daunting for guys like me with girlie calves, when I have to tighten up the strap almost to the limit.
The last major feature that I liked about the new VECTOR is the soft rubber insert on the inside of the sole. At first I thought it would cause me to slip off the pegs, but the soft rubber bites into any edge. So if mean old Mr. Gravity takes a hold on you over a jump and your feet come off the pegs its not so critical that the boots come down on the pegs aligned. Also the rubber wedge spreads out the force across the sole and reduced the aching in my knees two days after riding. If you ride a heavy bike like mine (KTM 640 Adventure) you’re likely to be exposed to more of the hard foot peg landing forces. The other thing that amazed me about the rubber soles is the vibration absorption capability. My bike is dual-sport and I like to ride on the twisty country roads around Madison Wisconsin. But the massive torquenstien of the KTM LC4 thumper tends to put my feet into a coma after a while buzzing along way over the speed limit. So the rubber wedge insert is now my best friend! The good thing is its replaceable.
Some of the negative comments on this boot that I’ve read in the magazines are that it doesn’t have that much ankle support. True, this is a 1970s feeling boot not a 1980s plastic feeling stiff boot. This boot is for guys who want the sensitivity and feel from a boot without the negative aspects of vibration or impact. The color of the boot is limited to a combo of black, gray, white, and even suede! Sorry no psychedelic colors or flavors of the month but if you’re really a color freak a little spray paint will fix that.
I highly recommend these boots for guys with big calves, lazy feet, and 70s riding styles that require a sensitive touch.
Eric Gorr
Posted by: smb_racing---------------------
the one thing I've noticed is the lack of a metal toe guard, is this hidden under the rubber toe area?
I've been looking for a comfortable boot for trail riding and maybe dual sporting, in your opinion would this boot be sufficient?
Thanks in advance.
There is no metal in the toe that I can determine.
Posted by: KawieKX125---------------------
Eric, you did not find the vents in the ankle annoying? I would think that they would let dirt and water in.:think
Posted by: kawiman---------------------
I have had my Vectors for over a year now, and had to go check for the ankle vents. They are there, I just never noticed them. Like I said, I have had mine for over a year, and the soles are fine. I have had no problem with the buckles. The only real problem that I can say I've got is that they have got fairly loose in the foot. Also, I am like Eric with the girlie calf syndrome. I have the strap cranked all the way. All in all, a very nice boot with a decent price tag.
KawieKX125, to answer your question, I get my feet soaked if it has rained a lot. But, there are some bike swallowing mud holes where I ride at. I would say in average woods riding conditions, where there is always some water, they stay fairly dry. Like Eric said also, the rounded toe kind of slides and pops over rocks with out catching.
smb, the toe cap on other boots keeps the sole from ripping backwards if it gets caught. On the vectors, the sole comes about half way up to the middle in front of the toe area. I got broadsided by a quad, and it nailed my left boot. Tire marks on the side, and something tore a small hole in the top of the toe section. I didn't even know that it had hit my foot and leg until I looked at my boot later on. $500 damage to the bike, and the boot saved me from at least a broken foot.
Posted by: Strick---------------------
Best boots I've ever owned! They feel like tennis shoes.
