Any other 450's losing coolant?
Posted by: U2leight---------------------
I bent my radiator neck first day out and repaired it, but now I am losing coolant. I thought it was my radiator maybe not sealing right but I have a friend who checked his and it was way down as well. I am going to try some type of engine ice and watch it. I know if they idle long they will spew it out but I am careful not to do that. Keep in mind it is 80 - 90 degrees here also, as some of you may be in very cold climates and I wouldn't expect you are having any problems like this. Just curious if this is a common problem. :think
Posted by: wayneo426---------------------
Maybe your shop overfilled the radiator? You will prob experience a few things when you break in your new ride. I left my WR idling when it was new for just a couple minutes, and it overheated quick! I have the overflow tank tho.
It isn't anything to do with over filling, it has happened many times.
Posted by: oabike---------------------
Dump the stock green goo and replace it with Engine Ice or Water Wetter. The stock coolant over flows after about 1 minute.
Posted by: Bud-Man---------------------
U2leight,
Just a thought, but maybe the "neck" isn't fixed. Or perhaps the cap itself was damaged. The cap has a spring loaded plate that seals the bottom of the neck and if there is any distortion it wont work properly.
My friend rode it in the dunes all weekend and it didn't leak a drop(I tore my knee last week and can't ride yet). I think it has to do with air flow on the track situation. I will try engine ice and see how that works.
