Bearing Clutch Lever Assy
Posted by: cloverdale---------------------
I want to purchase a bearing clutch lever assy. The cheapest one I found was motion pro 14-0110 @$56.90. However, I am looking for something that will last. Any one tried the bearing incorported units??
I convert my std set up to a bearing unit by going to a local bearing stockists, and getting a bearing with the same id as the od of the pivot bolt then drill out the lever hole to the same as the od of the bearing.Press the bearing in and hay presto a $3 bearing clutch lever assembly.
