I have the white and the do scuff easy, but o well.Fit great,adjustability is so easy and feel so good.
) but doesn't feel like they are sticking or stuck to the peg when I need to take my foot off. It sounds weird, but that's what it feels like. But you will have to do more maint. to these boots than you would with others (but if you want the best, it's not really a problem in my opinion). Blow out excess water from the buckles and pivot points and lube them after every ride and they are good to go:D The only boots to have IMO.
Originally posted by Jusitns-MR2 Those of you with the "SRS", from the reviews they say that it is hard to feel the foot pegs and brake pedal because the sole is stiff. Does this go away after time or do you just have to get used to it? |
Originally posted by KawieKX125 According to Gary Semics in the MX couse that I took, you are supposed to use your whole leg to brake while sitting, so the tech 7's you had were just super flexible. The only other gripe that I have is that they squeak like ski boots when walking. Kindof annoying. |
