Is Mobil 1 ATF a decent fluid for forks?
Posted by: blakemx124---------------------
I had heard that MX-Tech uses Mobil 1 ATF for their fluid replacement in fork revalves ane rebuilds. I do't know if this is true, but I was wondering if Mobil 1 ATF is a good/decent replacement for the stock fork oil in my '02 YZF.:think
Posted by: nifty450---------------------
Jermy suggested using it in my 426 forks so I did with good results. It may make your forks slightly stiffer than stock I,ll definitly use it again. good luck.
Nifty, What year is your 426 and at what level did you set it at in your forks (ie: 130mm from the top etc.)?:think
