92 KX125 For Sale $700.00
Posted by: tom656---------------------
I've got a 92 kx125 that needs a little work. It needs a clutch, fork seals and a rear fender.It was a friend of mines who needed some money. It does run and is rideable as is but the clutch grabs when you put it in gear.It had a new top end job early summer, but was'nt ridden very much.I'm located about 100 miles between cleveland, pittsburg and buffalo. Sorry I have no digital camera for pics.
Tom656 in Pa.
Posted by: Rockycr500---------------------
Do You still have this bike ?
yes I do, infact I took the clutch apart the other day and the nut that holds the clutch basket on was loose and it has a couple broken clutch springs, but the plates did'nt look bad, but I did't mic them. I have some cr springs I might try in it. If you wan't you can E me at tomlin1@alltel.net
Tom in Pa.
