metal shaving in oil filter!!!
Posted by: scar tissue---------------------
I was hoping to get some opinions on this.
I ride a '95 KLX340 built by Stoker.
I was changing my oil after our weekend ride and in the filter I found some metal shavings!!!! They are small and look like fine wire. I've never noticed this on my XR and assume its not a good thing. Any ideas?
The bike runs great and I'm having no problems with it. Should I ignore it till she blows? I've heard some bikes have magnetic oil drain plugs to catch these particals. Could it just be normal?
Any help is appreciated.
Posted by: buffmaster---------------------
I'm not too familiar w/4-smokes, but I found the same thing in my oil (and I am assuming you mean your gearbox oil). In my case, all it was were the shavings from the metal (either steel or alum.) plates in the clutch. They didn't look like little wires, thou', so it may be something else. Best guess, clutch plates.
Posted by: KLeeneX300---------------------
Some very tiny metal bits would be OK. I found some little ones (couldn't read a part number on them) in my oil, changed the oil and filter. On my next race the timing chain blew apart. Found big chunks in the oil that time.
Posted by: Jimmy!---------------------
Steel or Alloy fragments? Provided you haven't been into the motor recently and you've been changing the oil regular without any sign of debris in the oil filter up to this point, I'd be a little concerned. If it's a curly-q it may just be a pulled thread from an overtorqued drain plug or bolt. If you're sure that it's not something like that, then it's prolly worth peek under the valve cover, ignition cover and clutch cover to see if there any evidence of impending doom for your engine.
There's a small chance it could be something that was trapped in some other part of the engine and finally made it to the filter though. At the very least, I'd change the oil, do a short ride being hyper-aware of any unusual noises from the engine, then inspect the filter again for debris.
This isn't likely be what you want to hear, but that metal had to come from somewhere.
Good Luck!
Posted by: rollingp---------------------
Also no extra charge for metal shavings.
Posted by: mxbundy---------------------
Scar,
I wouldnt worry to much about it, every time i change my oil there is always a few metal shavings in there.
Both my 250F and my 400F have done this, with no problems so far. 2 years of hard riding on the 400F before i sold it.
Its probably coming from the gear box, those teeth and engagement dogs are constantly wearing.
later
mxbundy
Posted by: MikeOK---------------------
I would be more concerned if the oil filter was clean. That's what it's there for, to trap all the little bits that would otherwise be up in your cylinder doing evil things. Don't worry about it unless you start finding chunks...
Posted by: smarttoys---------------------
Correct, If you were to work on four stroke bikes and four wheelers for a living, you would see a lot of the same thing. It's very common to find some traces of metal shavings on the oil filter. The filter is doing what it's designed to do. Now if you start hearing noises or your filter is completely plugged with metal (which I have seen a few times) or find larger chunks of metal, then I would be concerned.
Posted by: Tiger---------------------
My 2001 KTM 400 leaves interesting bits of metal for me to find every time. Even when new. Even when ridden very little. That's why we change it often! Ride on and use less boot?
Thanks for you help.
As I 've noticed it becomeing increasingly hard to start cold. I took it to the dealer. I had alot of " other" projects to do.
It turns out one of the piston rings let loose and basically ruined the top end. the shavings were pieces of the ring. I didn't really want to spend the money on that right know. But It'll be great when repaired. $$$
Hey it's either this or my wife spending it at the mall.
Posted by: wayneo426---------------------
Scar-
Do yourself a favor and buy a magnetic drain plug for $15. It will catch and keep all the shavings from making the "rounds".
WO
