a bunch of questions
Posted by: ihillig---------------------
i recently had to replace my water pump seals and one of you was nice enough to give me the part numbers and a good place to buy them. i ordered them and i tryed to put them on my bike. i thought that there was only enough room for the one bearing and the larger seal. so i looked on the buykawasaki website and they showed 2 seals, and one bearing. but, next to the smaller seal there was a small thing that said ('91). so i called wholesale express up to talk to them and they showed two bearings, and one seal. i talked it over with a mechanic and he said there should only be one seal. i dont think i could get the other smaller seal in. i checked my service manual and i saw one seal. has anybody ever done this job on a '90? also, i did started a top end and one of my exaust valves were strpped. $30 wholesale. would wholesale express be the best place to get one of theese from or could i find one cheaper? and finaly, i wanted to put about 500 bucks in mods, all i have for mods is some renthal stuff and power reeds. i weigh about 240 and bottom out very easily. could this be just a maintanace problem or can i put $100 into this to make it work for me. what would be some good mods that i could do in a few hours and be done with it. i probobly sound like an idiot, but thanks for your help anyway
illig
Posted by: David Trustrum---------------------
I had seen that & assume it was an alternative or supersession. As mine is a 91 I ordered that part.
Do a search on ‘stiffening springs’ using the search key at top of screen. You definitely need stiffer springs & a re-oil maybe a re-valve of the suspension.
Posted by: motox---------------------
Oh, yeah i paid about 23.69 a piece for mine kips valves.
