Contact RB-Designs web site for further information including contact info.|
RB Designs is an Oregon based machine shop that is performing some very impressive modifications to motorcycle carbs. They bore the KDX carb to 36mm, install a venturi divider in the exit side of the carb, modify the jet screen, clean up the pilot circuit's bore, resize the throttle valve's cutaway and rejet the carb. The results are outstanding and its become one of my favorite mods. The off idle carburetion is excellent with clean crisp throttle response. You can easily lug the bike in a gear higher that you could normally and chug your way through the slickest conditions by almost eliminating unwanted rear wheel spend then when things oven up a little off you go. The bottom end becomes very 4-stroke like. |
). The honda XR springs are much better than any eibach, race tech or anything else in the run-of-the-mill replacement market
