Race tech Emulators
Posted by: KTMKRAZY2---------------------
Has anyone installed racetech emulators in a KTM65? I'm trying to follow their instructions for drilling out the compression ports in the damping rod, but according to their instructions I need to add two more holes perpendicular to the original holes and spaced in between. The problem is that it says I should end up with a total of 4 holes through the damping rod after I drill those 2. Well, the stock rod already has 4 holes through it stacked in a straight line. Now what?
Posted by: MikeS---------------------
Just drill the lower hole out. I think jer mentioned that there is enough flow already and too many holes will weaken the rod.
Good luck
Posted by: Jeremy Wilkey---------------------
Mike,
That is a good advice.. It's not like the thing hydraulicaly locks to start with..
Regards,
Jer
Posted by: Jeff Howe---------------------
So, whats wrong with overkill?:confused:
It's like running over decaying road kill to make sure it's dead:think
