Mabey a arm, leg, or whatever:confused: But please check into it before it's to late for you. As it was for me.
After I trimmed mine. I just taped over the peices I cut to make it look clean. But no one sees it under the jersey. And no, it isn't uncomfortable. :D
Originally posted by Okiewan We have requested a unit for review... |
Originally posted by XRpredator Trouble is, how much protection is enough? How much is too much? You can't protect yourself from everything. I'm thinking about one, though . . . :think |
Originally posted by Milquetoast I like the idea, and may buy one. One other thing I think it could do is have sort of a "backstop" for your helmet like some football linemen use. Maybe that could prevent serious neck injury from a head-first fall that pushes the head back? That's what got David Bailey I think, or maybe it was the roadracer guy, can't remember. |
Originally posted by AJ Waggoner So i guess i'm not sold on that device as it wouldn't help in a compression incident? I'm sure in other types of breaks it would be very protective and you should wear anything /everything available >shrugs< |
Originally posted by oldguy Wraith, is it flexible? Really wondering if the lowest section flexes and does it snag the seat at all? |
. It went down a little further than that (when new, not cut). And then I gradually cut (ever so little) more as needed, to keep as much protection on the lower part of my spine. But to where the protector would not grab the seat. I got mine to fit me where it protects all the way to the (top) fat of my butt. And this puts the protector (while sitting on the bike) just a hair higher than my seat. So this way, the protector is not sliding up and down if I'm on the seat. And it is best to do this (cutting, to get it to fit properly) however you are going to wear it. Like, if your going to wear it under a jersey and pants. Make sure you measure (before it's even cut) it while it's being worn under your gear. Because it will flex (slightly), depending on how tight you wear your pants. And this will make a difference, in fit.
I manage a Downhill MTB shop and this required uniform for all of my staff. If we didn't no one would ever come to work!!! We all wear it them under our CP, they breathe well and feel great.|
Originally posted by Titanium I really need to dig up that old article...I'm pretty sure he had another idea about an air-bag cervical collar thing that would be depoyed with a kill switch if you happened to leave your bike in a hurry. It was on the lower rim of the helmet; it could easily be detatched from it and used as a standard cervical collar on the way to the hospital. It wasn't even noticeable on the helmet, until it was needed. Ran off of a co2 cartridge, I think. |
Originally posted by DeanPrice475 I'd be interested in seeing how badly, if at all, this equippment increases the risk of concussions. If you stiffen everything up than you might not have enough give to avoid head injuries, which are also very dangerous. |
