Bike Getting Slow
Posted by: Slack_505---------------------
I am really having a power problem with my bike because.My family has gotten better at riding so we have been going faster. So I have found my self tapping out 5th gear tapped wide and I am not able to keep up with my dad.. I am not big enough to ride a bigger bike I currently ride a ttr125 with some mods on it like a pipe I am really stuck becaus I dont have money either what do you reccomend for me to do?
Seth
Posted by: Anssi---------------------
If you can't get a faster bike, you might as well start learning some technique. Try to get that underpowered juggernaut to wheelie or do some figure eights and stoppies and other kinds of drills. This will benefit you way more than trying to get a TTR to go faster and you will be readier when you get a faster bike.
sounds great but the thing is that I havent grown an inch in 2 YEARS!! I am worried that I will stay 5'2
Well, I have the opposite problem being 6'4", but even at 5'2" you can at least ride an 80 and those are plenty fast, especially if your weight is in line with your height.
Posted by: mxracer724---------------------
Get an 80 2 smoke. They are much faster than the TTR125, and arent big either. I started riding a YZ125 when I was 5'1", although if you got a 125 you might want one with a lower seat hieght, because mine was a little tall, but if you are trail riding get a CR, YZ, or KX 80, or even a KX 100, because the KX 100 has a bigger motor, but isn't much bigger.
Posted by: dell30rb1---------------------
I've got a cr 80. It revvs so high, and the powerband goes into the rev limiter, its not so good for trails, but it will do roll on power wheelies (no bumps or clutching) in third gear. You will have no problem keeping up with ur dad
What about boring out the motor I think that That might be able to get it a little faster..
Seth
The key word is "little". You won't get any significant power increase out of a TTR (compared to a 2-stroke MX bike) without a huge investment. I would get what money I can out of the TTR and get an 80 or the KX100.
You don't want to waste you time trying to make your TTR faster. It would be a waste of money. There is no way to make it even close to a 80 or KX100 mx bike. They are a lot faster. The 100 would probably be better for trails. Not only is the TTR not fast enough you have outgrown it if you are 5'2". It is time to move up. You will be able to keep up with your dad with an 80 or 100. You are big enough for a bigger bike too if your 5'2". You won't be disapointed with an 80 or 100. They are faster than a TTR hands down. I know someone who had a CR 80 and it was faster then his dads piped out XR 250.
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
