MOOSE easy-pull clutch
Posted by: exc rider---------------------
just curious if anyone has tried the easy-pull clutch system from moose and how it works or if it works? thanks
Posted by: Handl-it---------------------
The Ez pull I put on the old Maico made the clutch like a new Hondas. Then I lubed the cable! It really does work with many possible settings for the pull. I do recomend the cable luber you can clean and lube your cables and make the a huge difference in the pull. Do both and it would be like butter! I did seal the ends on the EZ clutch with silicone to keep dirt out.
