Fork spring pre-load
Posted by: jfisher304---------------------
I have an '01 426 with stock springs front and rear. The fork springs feel just a touch to light for me. Am right on the edge as far as weight goes between using the stock springs and going up one rate. I was thinking of trying maybe a 5 mm spacer to give it just a little pre-load and see if that would be enough to get it to my liking. Is there anything technically wrong with doing such a thing? If not, should the spacer go on top or under the spring, I have heard it makes a difference between suspension mfg.
Thanks,
Jason
Posted by: shockdoc---------------------
Yamaha has a part # (don't have it here) for the preload spacer & you want to make sure to put it under the spring.
doc
Posted by: eunos---------------------
We used spring preload washers (yam parts) to cure fork bottoming 250llb rider 2 in each leg and they worked great.However see my other posting re shattered spring guide I don`t know if this contributed to the problem.
