2000 Kx250 Fs
Posted by: Camstyn---------------------
2000 Kawasaki KX250 F.S.
bought new in June 2000, approx. 60 hours on bike.
Raced 6 or 7 times in Beginner class by spode owner.
Some of the extras include:
Renthal Twinwall bars, emig bend
Applied Works top triple clamp
Applied solid top bar clamp, oversized
Applied 15mm taller, offset oversized bar clamps
Applied Pro perch, teflon sleeve, roller bearing, easy adjust, CR style lever
Works Connection aluminum throttle tube
Oury full waffle grips
Pro Grip half waffle grips
Acerbis Rally-Pro hand guards, two sets, black, oversized inner clamps
UFO vented black front number plate
Acerbis silver front fender
Factory Effex carbon fiber fork wraps
UFO black fork guards
Am-Pro oversized front rotor, cauliflower design
DP Pro-MX front/rear pads
Michelin S12 front/rear tires
Michelin heavy duty tubes
Race Tech revalved/resprung forks and shock, extra OEM springs
MSR radiator guards
IMS 3.2 gallon clear fuel tank, never used, extra OEM tank
UFO black radiator shrouds
Fox/100% graphics kit
Ceet tall seat foam
Acerbis gripper black seat cover
UFO green side panels
4 No Toil air filters
replated/finished cylinder
recent bottom end rebuild with Wiseco rod and new bearings/seals
Wiseco top end kit, in the process of being installed
polished powervalve covers, kickstarter and clutch cover
V-Force Delta 2 reed cage
bare metal factory finish pipe
Pro Circuit 304 silencer, brand new, extra OEM silencer
Works Connection skid plate
Works Connection billet tranny filler plug
Factory Effex carbon fiber airbox decals
Fox/100% swingarm graphics
recent rear wheel bearings
DID 520VM gold X-ring chain, brand new
Sunstar Works sprockets, 14/51 combo, brand new
DP sintered rear brake pads
Bike looks, runs and feels better than new and has holeshot more races than not. Everything is tight. No rattles/worn out parts. Ready to win a MX race or an enduro. No prep work is needed on this bike, it's been maintained and is ready for many battles. Put gas in and race it.
I've got KTM fever. Medication not helping.
Located 2 1/2 hours north of Seattle. Will crate and ship. Delivery may be an option.
$3900.
mitchellc@acncanada.net
ttt
Posted by: Jamir---------------------
Man, I was going to offer you $11,000 for this bike. Why the price reduction?
Well, you see, I wasn't being completely honest before. All of those factory KHI parts? Well, they were just OEM stock stuff.:mad:
Now, that $3900 isn't firm. If you were to offer me $11,000 for the bike still, I'd probably take it.
Posted by: bigred455---------------------
CAM do you still have the stock pipe for that?if you do i am interested.
I sure do.. That is the stock pipe on it. I used aircraft coating remover to strip the pipe down to bare metal, then clearcoated it.
It's in great shape, with a few rock dings on the front but nothing major. Priv MSG me if you're interested..
Do you still have the stock air in the tires or is that Works Air?
It's a 60/40 oxygen-nitrogen blend set at 14 degrees below room temperature. Changed every 4 hours use.
What color is the powerband?
it's a carbon fiber one, teflon coated to make the power come on smoother.
