YZ426F Broken hubs
Posted by: XRpredator---------------------
I did a search and couldn't find anything along these lines.
My brother rides a '01 YZ426F and has broken the rear hub (and grenaded the sprocket as well) twice now. The first time we could kind of let go as maybe some bad hooey the original owner did, but after only about 10 rides, it broke again!
It looks like it broke out the bolts, then finally took out a chunk of hub. Bad scene all around. They were all held in by red Loc-Tite, ahd they were all tight when we took off this afternoon. Heck, the only bolt that was left was so freaking tight we couldn't move it!
Is there some kind of flaw with the Genuine Yamaha hub? Is there something else we're missing? Should he go for a Talon, and if he does, will it just be a more expensive break? Should we put this bike on the move list?
Any help you guys could give would be appreciated!
Posted by: MxKid512---------------------
I believe there was a known problem with the 00's exploding rear hubs, but I'm not sure about the 01's. :mad:
Posted by: eunos---------------------
Exploding hub.
We had exactly the same problem.Have a look at the holes in the sprocket where it bolts I think you`ll find they have gone oval.
It does`nt matter how much you tighten or loctite the bolts the sprocket moves when you dump the clutch and simply shears the bolts straight off.I believe this is caused by changing spockets and either not torqueing down correctly,eg.too much, causing the alloy to spread, or failing to use the correct washers and nuts. We found we had replaced the locknuts and the bolts did`nt come thru the nut far enough to lock.You do get some warning that it is about to happen, we kept finding odd bolts missing at the end of races, of course we replaced them with none yamaha parts which made the problem worse since they have different countersink angles under the head.
Since this sorry saga we have replaced the hub and sprocket with Talon and had no problems whatsoever. We also made sure we used talon bolts!
The moral of the story be extremely careful changing sprockets, use manufacturers parts and don`t overtighten.
Dont dump the bike for this, its far too much fun. I think you will find it was your mistake (sorry) especially when you say you could`nt move the remaining bolt.
regards kevin.
Posted by: Scott F---------------------
Do a search on Thumpertalk.com and you will find threads about blown up hubs. I suffered one on my '00.
Wow. This sounds like it's a lot more common than it oughta be. Seems Yamaha would step up and do something about it (like at least a service bulletin!)
I think the next one's gonna be a Talon.
Posted by: BadgerMan---------------------
I remember seeing a thread someplace (probably Thumpertalk.com) where it was suggested that running the chain too tight could cause damage to the hub. Since then I have been extra careful when setting the chain tension on my YZF.
Yeah, a service bulletin would be a good idea.
Posted by: wayneo426---------------------
Ive heard this before too. It must be the RED loc-tite. Big blue dont like that cherry red goo. :D
I have heard of talon hubs breaking as well.
I know one person who was doing the baja 500 and his excel/talon/white brothers hub grenaded while in first place on his yz-f 250.
Posted by: will pattison---------------------
the window for proper tension on the chain is pretty small for these bikes. all the grenade-hubs i saw were a result of overtightening.
wp.
Posted by: J.B.426---------------------
Will is right. The manual recommends 1.6 - 2.0 inches of free play. I would stay away from the 1.6. I always keep mine between 1.8 and 2.0 and have never had a problem.
Posted by: Ga426owner---------------------
I have been using the fabled 3-finger rule(at the right end of the top chain slider) on all 5 of my 426's 99-01. I never had a hub explode. Although, I have had the sprocket bolts/nuts loosen up after a race. These should be looked at before & after each ride......I believe if they loosen to a certain point hub havoc will set in as well as destroyed sprockets/chain.:whiner:
