F/S Scott damper bar clamp & perches (Husky)
Posted by: sparkycr250---------------------
I Scott top bar clamp and lower perches, 3mm offset foward or back mounting. Suited to fit with or witout damper system. For fat bar IE: Pro taper bars. Used two rides then I changed bikes...Give me an offer!http://www.scottsonline.com/dampacc...e=dirt#BarClamp
Posted by: YounGGunS---------------------
Hi, will be interested in your barclamp at $30 if its able to fit on 96'CRM250 stock triple clamp. I will pay for the shipping
YounGGunS
james72@starhub.net.sg
The width of the top clamp is 95mm across center to center from bolt hole to bolt hole. If that matches it should bolt right up. Any other questions I'll be happy to answer.
If you have a Husky let me know. I'll let these parts go cheap.
