Originally posted by TechKid I think you should go leaner since the race fuel carries more oxy. than pump. |
Originally posted by Papakeith Anyone gonna help me out on this one? |
Originally posted by Durt Cycler Watch out I read VP C-12 goes bad,dyno showed the bike lost 1HP after being mixed for only 2 weeks. |
Originally posted by Durt Cycler According to the guys at ATV News magazine |
| Excuse me while I go stand in the corner of the internet and bang my head against the wall. |
| According to the guys at ATV News magazine who did the test on VP C-12, 2 week old VP C-12, VP MR-2 the 2 week old C-12 ran 1HP less on the dyno when compared to the fresh C-12. They also have like 3 pages about fuel octane and compression ratios. This is the April 2002 issue. |
Particularly in this instance. I've been using C12 recently, & have enjoyed, for the first time in a while, a relieving decrease in time spent cursing jetting woes or trying to achieve reasonable throttle response. |
Originally posted by Rich Rohrich The temp range between the 10% and 90% point on the Torco fuel is fairly narrow with the 10% point being on the high side. |
just another hobby that consumes money and time
BTW i havent made homebrewed wiskey, but from what i have tasted i will stick to beer
:confused:
Originally posted by Papakeith Anyone else want to chime in? Are there any links available for some good reading? |
Originally posted by Rcannon our local area messes with the pump fuel during the year. |
Originally posted by andym I have access to Citgo 110, Sunoco 110, and 66 110. Which would be the best to use? |
Originally posted by andym The Citgo is stored in metal barrels but outside under a carport. |
Originally posted by Rich Rohrich Here's the hook though. If you are talking about going from pump fuel or one of the aromatic heavy cheapo race fuels to an oxygenated race fuel like MR2, then you may have to go a couple of steps LEANER on the main when using MR2. |
Originally posted by MikeeeP Rich box stock 03 KTM125SX... he has VP Ultimate 4 that he wants to run. Being oxygenated I didn't know what to tell him but to be safe and go up and work down. |
Originally posted by MikeeeP Did you see the latest results? Jeff Ward and Jeremy McGrath battle it out beating Mike Metzger and one of those famous road race guys was wayyyyyy back in 10th. LOL |
Originally posted by 2000SE B) Not switch and just say screw it and try to keep it clean |
Originally posted by Lobster OK, my understanding for jetting with oxy fuels is to go leaner. |
Originally posted by fishhead If you heat up your Jim Beam the alcohol will evap first then the water and finally the brown goo from the charred oak barrels that give it color and flavor. |
Originally posted by motometal Probably cut 50/50 with Amoco 92, or I may eventually talk myself into burning it straight. My primary goal is a bit of protection in case I get the jetting on the lean side. |
Originally posted by motometal Behind that, also throttle response, consistent jetting results (yes I know the pump fuel mixture hurts me in this area). |
Originally posted by motometal Reduction of spooge is always nice as well. |
Originally posted by motometal This possible reaction with the lead...would the result be potentially damaging or are you just referring to losing some or all of the benefit of the lead? |
Originally posted by motometal As I learn more about different fuels, I become increasingly annoyed that 99.9% of the population looks at "race fuel" as a commodity, as if there's only one type and all race fuels exhibit the same properties and characteristics. Sort of like comparing "steel" to "aluminum". |
Originally posted by motometal Any rough idea what the distillation curve would be for Amoco ultimate |
Originally posted by motometal If this theory is correct, many snowmobiles could be jetted much leaner if run on proper fuel |
Originally posted by Rich Rohrich No wonder these guys wear out main bearings and rods so fast, half their fuel is still liquid in the combustion chamber and running down into the crankcase dilluting the oil. :silly: All the idiotic my oil is better than yours posturing is pretty moot when 5% of your crankcase is filled with raw fuel. :silly: There is only so much ignorance driven smoke that can be blown up my butt before it gets hard to sit down. |
The last thing we need is irregular consistency in our gas.
on everything!
Originally posted by motometal Rich's response on Sunoco 110 was in reference to my application, which is a two stroke. I suspect this fuel would work a bit better in a "big" four stroke, more time to vaporize? No doubt still not the idea fuel though. |
Thanks Rich.
Originally posted by BigLou Rich-Is B35 any harder (or is it perceived to be harder) to jet for than B32? Just wondering why the local price is about a dollar a gallon more for the B32 |
Originally posted by Rich Rohrich It would be an OK choice in a low rpm, slow revving engine like an XR600. |
You truely are THE MAN! :thumb:
Originally posted by JTT Thanks Rich!! You truely are THE MAN! :thumb:
Originally posted by Rich Rohrich asking scary smart guys a trillion stupid questions they were wiling to answer (when they stopped laughing at me :thumb: ) |
Thanks again!!
Originally posted by JTT Thanks again!! |
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
