Can't get the reed cage out
Posted by: kadman---------------------
I have a 2000 250EXC. I was doing some maintenance to bike last night and decided to check the reeds while I had the tank off. The reed cage did not want to come out. This is the first time I have tried to get it out. Am I missing something here. I assume the gasket is just stuck but wanted to make sure before getting too crazy with it. Thanks
Posted by: the mayor---------------------
That's all it is. Take a block of wood and give it a whack....it will come off.
Posted by: Strick---------------------
You need to show it whos boss. The rubber attaches frimly to the metal. The mayor's advice is good. In the past I have just pryed them off.
Posted by: smb_racing---------------------
it helps to remove the bolts first obviously
Posted by: KTM-Lew---------------------
Stick a M-80 in the pipe and blow it out. :scream:
Posted by: kevan---------------------
mine was the same.......fuffed about for a while then bit the bullet........
big bita wood and whack..........hay presto.......out it came
Thats what I thought but I been known to screw things by getting a little heavy fisted.. I taped an M80 to a block of wood....one smack with a hammer and it blew right off. Thanks
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
