Pumper Carb for KLX300
Posted by: KTMdude911---------------------
What will getting a pumper carb do for my Klx?Where is the best place to buy one, and what is the best brand and model?Thanks for any help!!!
Posted by: velosapiens---------------------
i would buy from stroker, they come prejetted to be at least pretty close to what you need, and they include spare jets.
i have a mikuni 33mm. you can also get a mikuni 36mm or a keihin fcr 35mm. the mikunis are cheaper ($350 ish), compared to $500 or so for the fcr. the all work better than the stocker. go check out the planetklx mailing list, and search the archives for pumper carbs. there is a ton of info there.
what you'll gain is:
a) more power
b) much better throttle response and low-end torque. easier wheelies.
c) smoother over whoops and uphill jumps because the bike will no longer bog down on landing when inertial slams the slide down.
-mark weaver
Thanks for the help.
