tech tips wrong ?
Posted by: kdx357---------------------
i modded my stock pipe and silencer and now my bike is lean says a plug chop, the tech tips suggest putting a richer needle and the stock or leaner pilot and needle is this right. it is for a 89 kdx 200. please answer as i need new jets and i dont want to buy the wrong lean ones because i need richer ones right now.
Posted by: David Trustrum---------------------
Um, well the plug chop will tell you only Mainjet & has to be performed properly or is useless.
My 91 worked just peachy on site recommended jets. Some variation can be expected using different gas & oil mix ratio + from bike to bike etc.
I’d also check for airleaks esp in airbox manifold, filter, reed manifold, crank-seals etc just to be sure, then if you feel you need richer then go richer.
PS: for the less than full open jets make sure the slide isn’t grooved or it will leak, causing a lean condition, had to replace mine & yours is probably as bad.
Ah I see you've posted more than one thread, best not to do this.
Posted by: Canadian Dave---------------------
That jetting is in your bike right now? What temps, humidity, altitude etc are you riding in? Any mechanical problems like an air leak, carb problems dirty filter etc?
David
i think i got it straight now my float level was 1-2 cm off mine has a 158 main 48 pilot and 1172n needle it was a rainy 100% humidity day about 40 f and i had a nice tan on my plug , i figgure it will get richer as temps go up so i think im clear. but if i snap the throt at lower rpm there is a little hesitation, not quite a bog just a little hesitation , any insight . is this normal , i just modded the pipe but it still has massive dents in it , it has heaps more power and the hesitation has been reduced, if i pull the dents how much more power will it make ?
